What is the reason for the leveling lift kit
Blueinterceptor
What is the purpose of the 1" leveling kits in the front of the tahoes and burbs? How much room do you get. Is it primarily cosmetic
DWSmoot
Charleston, SC
People generally add leveling kits because they don't like the higher rear stance and/or to gain clearance to run larger tires.
PG01
Up here to the right
The 'block' or 'spacer' you put in may be 1" but it amplifies to 2-2.5 after all said and done.
WillCO
Castle Rock, Colorado
Personally, the slightly raised stance in the back has an appeal, it looks athletic.
I get why people going for a more urban look might want to do it though.
PG01
It lifts the front and levels it...not sure how thats 'urban'.....as 'urban' refers to city dwelling and 'suburban' refers to outside of city living so, as in my case, i wanted my truck raised up a bit....guess im a ****** hillbilly tho...
WillCO
Maybe you are, I don't know you.
I actually thought the process lowered the back, versus raising the front. Normally lowering suspensions is a city thing, as it trades utility for appearance. So that was my thinking. Clearly I was wrong.
eod_tech
