What light is this?
Smasal
Southwest, Mo
The inside Amber light never comes on? Are both bulbs out? Does it even work? I'm confused. Hopefully someone has an answer here?
Alex33
That's your Daytime Running Light. If both are out, you're bulbs are probably just burnt out.
03Dnasty
Kansas, Rock Chalk!!!
I believe you are talking about your Daytime Running Lights. If this is the case they only come on during the day, when your headlights are NOT on and the truck is out of park. When I bought my truck, both were burnt out and I had to replace them. Common thing to happen when they are supposed to be on 90% of the time. Anyways, bet if you swap those bulbs out, they'll work! :happy107:
soulsea
Bar
If it's not the bulbs check the fuse ... not sure if you bought your truck new or used, but some people don't want DRLs and they pull the fuse.
Smasal
Smasal
Southwest, Mo
The guy I bought it from could have pulled the fuse.He was big on appearance and may have just not wanted drl's. I'll swap bulbs tomorrow for starters. Thanks guys!
soulsea
Bar
Noes ... those are filament bulbs.
Smasal
Smasal
Southwest, Mo
Wow...that's what I meant. LEDs would be nice. These look kind of dull under hids.
patniven
