What offset?
OilfieldTrash78
What offset would I need to get in order to run a 20x10 wheel on my ‘16 Denali with a 2.5F/1.5R level?
Thanks
Nokturnal
Thanks
I ran a 20 x 9 0 offset with 33x12.5 Toyo RT with no rubbing. I have the same 2.5 F/1.5 R.
I recently switched to a 20x10 -24 offset and there was significant rubbing and trimming required. I am now looking into 4” Lifts bc even with the trimming there is minor rubbing.
4OFFSHR
CA.
I'm running a 22x10 with a 0 offset, and my tires are out about 3/4" to an inch, it is aggressive but with the lift it is the right look in my opinion. I have a 2" level in the front and finished adding a 1" to the rear today. Couple images attached so you can see how far out they are. But most of the wheels in the offroad application in a 20" are a 0, or -12. If you run the +20 or higher I think it sits in too far and doesn't really give the truck an aggressive stance. Just my 02.
Nokturnal
20 x 10 -24 Offset
I know it’s not 22” wheels...but at least you’ll know how a negative offset with 10” width looks....and rubs haha
A189DB64-A174-4FE4-9F89-57CAE8F45477.jpeg 04EA7B1E-934C-40E2-9A7A-CB5437F71333.jpeg
Nokturnal
What wheels are you running? That’s the other issue I am running into. Is your truck Iridium Metallic?
I’m running XD Grenades Satin Black. Yeah my rig is Iridium Metallic. I’ve gotta figure something out ASAP on getting the front up just a tad higher. Thinking Fabtech 4” Front Only to get maybe an inch more height for rubbing solution.
My front fender is sitting at 38” and everyone seems to be at 39” with Fabtech 4” Front. I’m kind of tired of the ride hop I get up front anyway w the leveling kit.
O
OilfieldTrash78
What leveling kit are you running? I haven’t heard of any issues with the Suspension Maxx kit I have.
Nokturnal
That’s the 33x12.5?
Yeah both wheels offsets have the same 33x12.5.
I’m running the suspension maxx
Kit. The hopping is only noticeable over highways bumps. Kind of floats versus absorbing the bump. Guessing it’s from the compressed front to accommodate the spacer.
ToddYYC
