What pin is the reverse wire in the BCM
NathanJax
Vacation Nathan
Administrator
Jax, Fl
The info I have...
"The BCM is the control module directly under the steering wheel. There are several wire harnesses plugged into it facing the drivers seat. the on furthest to the right has only three wires. One of which is light green. This is the reverse wire."
JKmotorsports
Austin, TX
The reverse wire can also be found in the a-pillar trim. Light green wire.
JKmotorsports
Austin, TX
got mine at the a-pillar also. weird spot i thought.
The reason it's up there is because it goes to the rearview mirror. The auto dimming function of the mirror is bypassed when shifted into reverse so you can see when backing up.
707jimenez
