BogeyBoy82
Just put a 2/3 mcgaughys on my wifes 08 tahoe and now its wheel/tire time. I'm gonna go with 24s but I'd like to get her as much sidewall and less rubbage as possible (i know thats a semi-oxymoron). My experience is its usually the width of the tire that will rub sometimes more so than the height. So with that said I've been looking at the 285/40/24s over the typical 305/35s just because it gives you just a tad beefier sidewall althought almost negligle.
So with that said guys running a 2/3 what size tire are you going with on 24s or if you don't have 24s post up your tire specs (ill do that width/height math) and your rubbing issues along with wheel offset if you got it.
I know most rubbing can be solved by a little trimming but I'd prefer not to. Also on these trucks is there a quick speedo fix for the slightly larger in diameter tires?
