what to lube barn doors with
95escahoe
On my 95 tahoe the barn doors are a lil hard to open they used to open mint, what would you use to lube them, wd40 or that white grease stuff or is there something else? thanks for the help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
wd-40 at first to get all the grime out then white lithium grease a couple of days later. I actually wish my right one was much stiffer to hold its place. Left one is.
crows feet
Elberton Georgia
i use just plain greese,use a greese needle,fits right in those tight places,dont poke yourself.great fro greesing that anoying squek at swaybars rubbers....
95escahoe
95escahoe
not a bad idea either, did the wd40 today works alot better gonna use the white grease in a few days and see how that works, if it doesn't ill look into that, thanks for the info
twopoint
Kitsap County WA
I have tried lithium grease and have had some issues with dirt accumulation.
I now use graphite, it seems to work very well.
bowtiefreak
No Quarter
Near Philly
very familiar with it. I sold the machine that puts the powder in the cans, I had tons of the stuff at one point, good stuff.
crows feet
Elberton Georgia
still say plain greese from agreese gun thicker and dont wash out...more tackey than white greese.....useing the needle can get your bushing good,sounds like need to replace your pins and bushings,when the bushungs get wore out they fall apart and start binding.thinkset of 5 are 25 bucks,be sure and ask if come with bushings,not hard to change,DONT LET DOORS FALL AT ALL,,,,thats how you adjust the doors,open and pull down or up which ever,little at time tho.
memakos
