Alabamakayaking
- Joined
- Jan 25, 2017
- Posts
- 26
- Reaction score
- 9
I have an '08 5.3 flex fuel 6" lift on 35's. It shit the transmission. Pulling thr trany myself taking it having a stage 2 rebuild done. Below is a rebuild specs that I received. Do I need to replace the kickdown cable and What torque converter should I use?
$750 master over haul kit stage two clutches and upgraded seals and plungers , corvette servo , new upgraded sun shell , high performance clutch brake, rebuilt pump , valve body rebuilt , the transmissions when I build them I strip them down to the shell and completely rebuild them I only reuse the hard parts I clean then and inspect. Everything built with specs , I don’t replace the kick down cable or torque converter. Orielly Autoparts is cheaper for to get it and install then it would be for me. I give a 6 month warranty only if the converter is changed
