What torque converter? Stage 2 rebuild
Alabamakayaking
Alabamakayaking
That can was already opened, you're just now realizing it! Fortunately, it's not a lot of worms and you can easily put them back and fix it so that it doesn't open again. If you don't beat on your Tahoe and the lift and tires is more for looks and light off-roading, get the appropriate gearing for those tires (unless there's a good chance you'll be downsizing, then gear for those). Then you'd be fine with a mildly-built trans that just addresses the 4L60's common failure points. Having proper gearing will make the vehicle feel like it's stock to the trans. It's cheaper to get proper gears than to build up a trans to stand up to all the extra load. For the converter, you'll have to ask each converter manufacturer what they recommend. They'll build it based on your vehicle's weight, tire size, gear ratios, intended use, etc. You really just needed guidance on what converter manufacturers to look to, and you've gotten that.
Yeah I know gearing is important I had a '99 classic supercharged headers aftermarket ignition system Dick cepek suspension custom built shock mounts 12 shocks , ladder bars and body lift geared 5.38 sitting on
40" groundhogs It was a bad ***** This shit box struggles every where it goes
Alabamakayaking
Alabamakayaking
IF you buy a monster trans, plan on another trans within 6 months..
Nuff Said on That !
I just searched the reviews and there's a damn good chance of that and it appears their customer service sucks
1BADI5
DMV
I agree with the other guys as well, can't go wrong with Circle D. I got a billet 3200 stall converter from them. I placed my order over the phone, gave them my specs and done!
Around town and on the highway, drives like OEM.......but when you give it the sauce, its a completely different animal
Alabamakayaking
Alabamakayaking
I'm trying to get out of this without spending $3,000 + but it doesn't look possible done Even close to right
ToddYYC
