What transfer case do I have and how does it work
Jr_454
Minnesota
Hey everyone I have a 05 Yukon with awd it is not a denali . Does anyone know what transfer case it is and how it works. Also has anyone answered the G80 question is it locking or a limited slip.
thanks all
thumper_ehhhhh
Canada ehhhhh
The transfer case is at the back half of the transmission. It transfers power to the front wheels. When you put it into 4 low it slides another gear across to give it a lower gear ratio. Because you are awd you cant switch it to rear wheel drive only. I think that would be a great mod for someone to do.
According to this rpo look up it can be both lol Here's the link.
http://www.gm-trucks.com/rpo-code-lookup/?find=g80
ecordell
CordellDesigns.com
Merica
On these AWD vehicles doesn't the front drive shaft turn all the time but not actually engage the front differential until needed?
redemn93
Jupiter, Fl
that sounds correct.
and if you have no need for it and dont use it, you can remove that driveshaft for better gas mileage. i personally like mine right where it is from factory. :)
J
Jr_454
Minnesota
what sets the tcase to engage the front end is it wheel slippage. and is this a weaker transfercase then the standard 4x4
emfadz
