As most of you know I just had my 99 re-geared. After the swap from 3.42 to 4.56 there was some vibration issues. The guy that had it before me installed the lift and didn't lengthen the rear drive shaft.
I had a custom drive shaft made for the rear and that got rid of most of the vibration but I still had some vibration in the front end. I pulled the front shaft and the vibration is totally gone.
What I can't understand is why do I get vibration from the front shaft when the Hoe is in 2 wheel drive? What is turning the front shaft.
My Hoe has the auto-4wd option on the transfer case. There are 4 pushbuttons, 2wd, auto 4wd, 4Hi and 4Lo.
With the front shaft off and rolling the truck in the driveway with someone watching the front diff yoke, it doesn't appear that the front diff yoke is turning. The transfer case shouldn't be turning the shaft in 2wd should it? I'm thinking maybe the Hoe is actually dropping into the auto 4wd mode and turning the front shaft because sometimes the 2wd light goes out for no reason.
The front shaft goes to the machine shop tomorrow to see if it needs balancing. More than likely I'm looking at a custom drive shaft to help flatten the shaft angle like on the rear.
I'm really curious whats turning the front shaft in 2wd.
