What Water Pumps Will Fit 2003 Yukon XLT
campbmic
Hey guys! I need a water pump for my 2003 GMC yukon xlt. I was planning on going to the pick n pull to get one. I was wondering what other trucks and years would work?
Thanks!
about20ninj45
Without changing your configuration, 01-06 gmt800 trucks use the same water pump iirc.
about20ninj45
lol i didnt question that, figured he knew that already and was doing a project of some sort.... some haggard garage type ish
Yeah I was just thinking out loud but I'm still wondering. Clue me in Michael!
Aaron_L
Arlington, TX
Why would you get a used one? A new pump is cheap. Plus the effort to pull one at the yard, and then pull the one of your truck, and also any unforeseen problems, it's just not worth it.
C
campbmic
Money is super tight right now so $15 seemed better than $100 (I thought they were that much through auto zone new).
Seeing $60 would probably make me change my mind. However, theres a part that broke on the old pump. Its the "T" that brings two hoses into one and plugs into the side of the water pump. I haven't been able to find a source for this "t" so I figured I could just grab it with the water pump.
Wikipidea says the 2003 Yukon was a GMT 830?
https://en.wikipedia.org/wiki/GM_GMT_platform#GMT_800
Would pretty much any of the "GMT" trucks listed in that section work for me?
Thanks everyone!
EDIT Here's the part I was talking about I think;
https://www.amazon.com/Gates-22554-Heater-Hose/dp/B000C2WDTW/ref=pd_sim_263_11?ie=UTF8&dpID=215M8GY84FL&dpSrc=sims&preST=_AC_UL160_SR160,160_&psc=1&refRID=DBQHY2AKXMWGBA808CV1
Would anyone know of a source for just the "T" connector?
Maybe this? If I recall the hoses are 1" and 3/4" that come together to make a 3/4" (thought I could be remembering wrong).
Aaron_L
Arlington, TX
Thanks everyone!
The "T" is part of the hose assembly. If you're on a budget you could cut the broken one out, and replace it with a barbed hose "T" and some hose clamps. You can get them in brass or plastic, the hardware store or auto parts should have them. Just cut the old one out as close to the joint as you can, so the hoses won't be too short when you join them back together.
The "T" is definitely something I'd get at the wrecking yard if money was tight. It would be easy to cut off the old hoses too. Or do what Aaron suggested.
wiser1
