What wheels fit our trucks/stock tires?
blizz
San Antonio, TX
I'd like to start buying some wheels for the hoe but I'm not sure what I need to be looking for as far as bolt pattern offset etc. I have 285 75 r16 grapplers on it now that are practically brand new so I need them to fit the wheels. I'm looking at Teflon Mojaves or chambers.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If you have 6 six lug axles then you are looking for a 6x5.5 lug pattern with 14mm lugs size. Maybe it was 14.5. I forget atm. I have had or do have a 4.5 backspace and zero offset at the moment I think on mine and have a 17x8 rim size. Bigger has been done tho. You should be able to find the same specs except rim size of mine for yours and have a lot to choose from that will fit with ease. 16 will likely have a 4 to 4.5 backspace and off set of anywhere from 0 to -12 mm.
bills02yukon
What size hub diameter do these trucks use?. American Racing has a 78.3mm and 108mm hub bore
Kjuergens
