What's a good muffler for a 99 tahoe 5.7
copperchevy
Im looking for a part number for magnaflow or borla muffler for a tahoe 2 door. Im having trouble finding just a muffler thats a dual 2.5" inlet and single 2.5" or 3" outlet. Or does anybody know if borla mufflers are reversible.
AtomicHoe094
Atomichoe094
cleveland, OH
Summitracing.com will probably be the easiest. I dont think much is a "direct" fit for these trucks, youll need to do some clamping or welding done. The stock mufflers on these things are like 3 feet long..
TigerEyz3
Slow and Steady
TN
Factory dual exhaust pipe size is 2" from the manifolds (technically 1-7/8"). Factory single exhaust pipe size is 2.75"
You'll be safe with a 2.25" dual inlet muffler (or a 3" single inlet muffler)... exit diameter is up to you. As Atomic stated, you're gonna clamp or weld the connections (welding is gonna make a better bond/seal obviously).
Administrator
x2 what atomic said. Virtually nothing will be a direct replacement and will require some modding of the exhaust but summit racing will probably be the easiest to get what you want. You may also get lucky on craigslist if you know exactly what you're looking for...
Brandon X
Michigan
They're reversible. I called Borla themselves and they said they were. I have this one: http://www.summitracing.com/parts/BOR-40349/ and turned it around to have my 2.5" duals run into it, and had a turn-down tip welded on the single outlet and dumped it right before my rear axle.
BattelWagun
Chi-Town USA
Sometimes when systems break in (particularly high flow mufflers and headers), they can get a little louder. Can't hardly notice though, if you notice at all.
jeffrocates
