Whats under the amber side marker on the headlights?
Strip5150
Im trying to get that clear look for the side marker in the headlight assembly. Ive read dremmel is the best way to go about getting it off but whats under the amber and/or where can I get a clear side marker?
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Best way to go clear is to bake the light at 200 degrees for 10-15 minutes in your oven on a cookie sheet lined with wax paper. Immediately pull lense off. To reseal go to Lowe's and get sealant and tightly wrap and let sit until sealant cures.
Sent from my myTouch_4G_Slide using Tapatalk
B.G.
Dont attempt this if your headlights are OEM. Its almost impossible to pull them apart wo complete destroying the headlight. The lamps are plastic fused to gether. If your going to attempt these get an OE set of headlights from the supporting vendor on here. Think he sells them for $150 shipped. These you can pull apart based on the above method..
ehernande86
