wheel and tire lift combo
kbi83
hey guys new to the board but ive been lurking around for a couple of months, i was on the fence about what i wanted to do with my 2002 4x4 **, i just took it to the shop to get all the scrapes and dents fixed so i guess im keeping it for awhile..
im new to this lifting and my friends arent much help.. so im looking here
im looking at the Readylift SST for a mild lift.. that part is straight forward and i will probably end up ordering a 2" or 3" spacer for the rear
heres where im lost:
wheels:
XD Series XD775 Rockstar Wheel
20x12, 6 on5.5 Bolt Pattern
Backspace 4.77 in.
Max Load = 2200lbs
Finish = Matte Black
Hubcentric = No
Offset = -44 mm
tires:
Nitto Terra Grappler NTGAT
275/55R20, Terra Grappler
Load Range = XL
Max Load = 2833
Tread Depth = 13/32
Overall Diameter = 31.80 inches
Sidewall = Black
those are the wheels and tires i want to run.. so will these work with the lift without trimming??
thx for the help.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
The readylift only works for 07+ trucks. You can prob fit those tires just by cranking the stock keys. If not, look into rough countrys leveling kit. Comes with everything except the rear spacer. 1.5" would be good for you.
K
kbi83
thx for the reply,
i kinda wanna do 2 and 2 to try an keep it a level stance.. but ill look into that rough country
AquinoSteven
Key and Spacer Guru
Clinton, NJ
youll get about 1.5"s out of stockers. My fenders sat at 36" cranked all the way. Im not at 40" with new keys and 305s
---------- Post added at 10:24 PM ---------- Previous post was at 10:23 PM ----------
Remember that theses truck come with rake from the factory. I only did the 2" because the rear was sagging. If you rear is higher now it will be after the leveling kit
polobuds
East Bay, CA
I have an 03 tahoe and I'm running BFG 265/75/16 (31.6"). If you want to put on tires that are 31.80", you should have no problem even without cranking the keys. And like steve said, if you go 2 + 2, your rear will still be higher if you have the stock rake. I was thinking of going rockstar wheels and grapplers as well, but I'm trying to fit 33", so I might just crank the stock keys up 1.5" to eliminate the rake and level it out
K
kbi83
i keep thinking and researching new stuff..
if i go with 2" keys and 1.5 spacers could i run 305s? without rubbing or trimming?
305/50R20, Terra Grappler Load Range = XL Max Load = 3086 Tread Depth = 14/32 Overall Diameter = 32.09 inches Sidewall = Black
K
kbi83
bump..
im ready to order this stuff..
can i run these wheels and tires with just a 2" leveling kit?
Backspace 4.77 in.
Max Load = 2200lbs
Hubcentric = No
Offset = -44 mm
P275/60R20, Terra Grappler Load Range = Passenger Max Load = 2601 Tread Depth = 13/32 Overall Diameter = 32.99 inches Sidewall = Black
i believe i read somewhere i should be able to clear 33" so just makin sure ive done all my homework and everything will fit without trimming..
thx again
AquinoSteven
Key and Spacer Guru
Clinton, NJ
you should be good, gonna rub a tiny bit because of the offset but youll be fine. I got 305s and i barely rub.
Heres my new setup
Gibbsy74
