wheel bolt (stud) size and length
skychair
Can someone tell the me the over all length and size of the wheel bolts for the 99 Yukon?
I think the size is 14mm x 1.50, but not sure about the length.
I need extended length bolts to account for 1/2" spacers.
Thanks in advance, Ron
east302
Mississippi
Take a look at RockAuto.com, select your vehicle and search for 'lug stud.' It pulls up several manufacturers, but it looks like the lengths are given for front/rear and two/four wheel drive.
S
skychair
Thanks for the reply, my solution to a tire clearance problem is solved, I decided to get new 1" 5x5 to 5x5 spacers and gain the additional clearance needed. I have a flat 1/2" spacer that was installed 7 years ago, but driver side is rubbing, probably due to worn suspension.
Thanks again, Ron
meow
