Wheel offset on NNBS Denali with 2.5/1.5 lift
GulfCoastDenali
Gulfport, MS
I have an 07 Denali with a 2.5/1.5 lift installed. I have a buddy with a set of 20x10 Moto Metal wheels with -24mm offset that I can get pretty cheap. I'm wondering if these will clear with 285/55R20 tires? I've searched through the threads here and haven't found anyone running this setup, so I was just wondering if anyone had any insight on this. Thanks in advance!
01Konvict
Boats n Hoes
Raleigh/SML
Don't think it will clear as the offset is too deep for a mild lift. It will be close but requires some trimming. Test fit a run on the front and see. Most likely rub the bumper corner.
GulfCoastDenali
GulfCoastDenali
Gulfport, MS
I read through your build thread and could handle a trim job similar to yours. My main concern is the rear side of the inner fender. Thanks for the heads up! Sweet looking truck, by the way!
01Konvict
Boats n Hoes
Raleigh/SML
Yeah the corner isn't much to trim, just need to cut the bracket on the inside and pull the liner forward with a L bracket. The rear might scrub the running boards or fender itself. So you would need to do a large NorCal fender mod (google on GMFS). Really thinking it would look out of place with that much offset on a level lift IMO. They will stick out 2-2.5" from the fender and think a 0mm (5") offset would look better only sticking out 1/2". Thanks for liking the truck! I love it and drives great!
younggunn187
