When should I replace shocks
dsf260
Newbie to auto maintenance here (and the forum)
I have a 85,000 miles '05 Tahoe LT with the Premium Smooth Ride option. I am not sure how to tell if the shocks need replacing—any advice would be appreciated.
I can do a bounce test (i.e. got the car moving up and down by hand) and it does settle in 1 1/2 oscillations front and back—is that ok?
I would really like to avoid having to replace the shocks prematurely—the rears go for $300 each. Given current circumstances, I need to push that off as long as I can.
BTW, is this something I can take on myself? I do have a set of jack stands (rated 4,000 lbs) and a floor jack—is that the right equipment?
Thanks for the help.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Monroe recommends replacing shocks and struts every 50,000 miles. Personally, I see no point unless they are leaking our excessively worn. Shocks are much easier to replace than struts. In the rear I think it's only 2 bolts each shock after lifting the truck and supporting the rear axle.
Sent from my myTouch_4G_Slide using Tapatalk
Administrator
For what its worth i just replaced my rear shocks a couple months ago and I believe they were originals and my burb had 115k at the time.
I could tell it needed due to the bounce test :)
tahoe7689
Like the previous poster said you can kind of tell when you need new shocks....I believed I replaced my original shocks around 100k miles. It is something you can replace yourself, I did it myself with the equipment you mentioned above. The front and rear shocks have a bolt on the top and bottom, 00-06 tahoes dont have struts so its easy to replace the shocks. You should invest in a chilton or similar type manual for your tahoe. They sell one for 00-06 GM SUVs and it will give you step by step instructions for the shock replacement
pewtermetallica
