Where is the ground for the rear tail lights/signals?
blizz
blizz
San Antonio, TX
Found it. Took bolt off used the dremel to clean terminals, used dremel on frame where bolt goes, and put it back. I also had two more grounds that weren't properly ground. One for the trailer wire harness and one for a 7point trailer hook up so I drilled another hole in the frame, and properly grounded them. Last, I replaced the tail light circuit board with one I had laying around and now I have brake lights and signals on both sides. I HATE those damn circuit boards. Is there any way around them? Any way to not have them?
95escahoe
Run LED tail lights no circuit boards then
Sent from my HTC One X using Tapatalk
95escahoe
Hmm. What are u running and where did u get them?
I got them on Ebay they were under $100 many people on gmt400.com run them and have had no issues, plug and play no other mods needed
ccapehartusarmyINF.(ret)
Gilbert AZ
i know the ground for the front signals is behind the left side of the front bumper so i would assume its on the frame some where behind the rear bumper
blizz
blizz
San Antonio, TX
So now the tail light and blinker aren't working on the other side. I get the fast blinks when I use the signal. Wtf!!! This is driving me crazy. I would just get the led lights but I'm not convinced that something won't go wrong with them. Where else should I look??
pdrahcir
