Where to buy new keyfob remote?
ypsetihw
Lakewood, CO
Title says it all - our Tahoe hasn't had a functional keyfob remote in 5+ years and I'm sick of it. Where can I get one and have it reprogrammed? Is coding it something I can do myself or can a dealer accomplish this?
:beer:
bsims3996
alabama
you can get them on ebay anywhere from $10- $50. some sellers will give you the instructions when you buy it, but if not google it and you can find instructions. its not hard to program though
Teqdogg
Well, I got one when I bought my XL, but wanted a spare. I matched the P/N number and FCC ID on the back of the FOB to the one I ordered, but the website I posted matches it with your year.
From looking at it, all 2003-2006 Tahoes, Yukons, Silverados and GM trucks use the same FOB. I just checked and 2001-2002 use the same FOB, but different from the 03-06.
Redhoe01
The BDG
Forney, TX
Can anyone get the P/N # and FCC ID from the back of their 00-02 fob so I can make sure I get the right one. I dont have my original fob to match it up to.
Teqdogg
Red,
Your info should be:
P/N: GM 15732803
FCC ID: KOBUT1BT
but maybe someone with a 01-02 can confirm...
ypsetihw
ypsetihw
Lakewood, CO
used original? on ebay say this:
GM/LEAR 15042968
FCC ID: KOBLEAR1XT
CANADA: 3521 102 1718
new ebay w/ trunk button say this:
GM: 15043458
FCC ID: KOBLEAR1XT
HAS LOCK UNLOCK PANIC AND REAR 2X BUTTONS
Teqdogg
GM/LEAR 15042968
FCC ID: KOBLEAR1XT
GM: 15043458
FCC ID: KOBLEAR1XT
Apparently the one I posted for 2001 (15732803) and the one posted on the top (15042968) by ypse both work on 2001, however, according to the website:
"NOTE (1): GM used one of two different remotes in 2001 and they do not interchange. Please check the numbers on the back of your current remote to make sure they match this one. If you are sure you have the factory RKE system and you do not have a remote, there is no way to tell which one you need for 2001. Your only option is to buy both, and return the one that does not work for a refund. We cannot tell you which one you need, nor can the dealer. GM test A will not tell you which one you need, only that an RKE system is present."
CaptPat
