Which is the best most reliable way to lower 05 Tahoe
BADRIDES
I have Belltech spindles in front with torsion bars turned down. I have Mcgaughy rear springs with no spacer. I have Belltech shocks all the way around and love them. Also have Belltech front and rear sway bars. I sit at 33 in front and 33.5 rear. 285-45-22 tires
donbalo
Got a 2/4 drop on 24s no rub no banging full upturn and change all my bushings and whole front end and ride stock belltec spri gs and spindles and shocks
Slammedchevy01
Intermediate steering shaft loose? I know they had a lot of issues with that.
setconstr
setconstr
Crazy but there is nothing that is not new in my suspension and I still here the same noise when I turn the wheel pulling out of my driveway or over a bump the sway bar is sorted out ....The only thing I haven't replaced is the steering box and lower steering column link ..On the road it drives Awesome, very tight, Great over bumps or chuck holes just that noise is still there, I hate noises
signguy62
NJ
I have Belltech drop spindles, belltech shocks, belltech sway bars, Spohn pan hard bar, Spohn lower boxed rear control arms, Djm rear lower control arm relocation brackets , Djm rear sway bar links, 22" wheels, it's a 3" x 5" drop. relocated the rear bump stops ( free travel ) ....Truthfully I hate the ride and the front end keeps loosening up I had everything tightened up at an alignment shop and now it's making the same noises ( clunking ) when I turn the wheel as before.The alignment shop said all front end parts are good . Is there a better way to go ? coilovers ? air ride ? I just want it to be super tight I know the 22's won't ever be Great but I'm putting some Michilin Pilots or Toyo tires soon maybe a bit bigger
Yeah, I know it's an old thread. But I've been look for a certain parts combination and you're the first I've come across who is running it.
You have the Spohn boxed lower control arms with poly bushings and you're running them with DJM's rear hardware kit (the lower arm relocation brackets) specifically? I have the DJM pieces installed and was looking at the Spohn lower arms. But some have said they won't fit. But you got them to work?
setconstr
setconstr
They fit no problem I don't have that Tahoe any longer I bought a 2018 but really wish I would have kept my older Tahoe it was dialed in
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Text me buddy. I've done thousands including my own
415 519 2432
Sleepy01
415 519 2432
Hey man. I'm looking to drop my 2001 2wd Tahoe. Think I want to go 3/5. I'm also doing some performance upgrades as well. I'm new to the lowering world. Any advice and help would be super appreciated. Thanks in advance.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Shoot me a dm buddy
mckaywolf
