DragonSlayer1
- Joined
- Jun 13, 2023
- Posts
- 5
- Reaction score
- 4
Hi All: Which motor mounts would you suggest for 2008 AWD GMC Yukon 6.2L. From what I'm hearing the stock ones are not being suggested.
Thanks
Thanks
Hummer motor mounts (2), GM# 25847739Hi All: Which motor mounts would you suggest for 2008 AWD GMC Yukon 6.2L. From what I'm hearing the stock ones are not being suggested.
Thanks
If you don't want any engine vibrations and don't dog the motor all the time, the factory fluid filled mounts are fine. But if you want something more durable and don't mind a little engine vibration at idle, the H3 mount that Don posted is the way to go. I run them both on mine. The Yukon gets the stock mounts and the 6.2s get the Hummer mounts!Hi All: Which motor mounts would you suggest for 2008 AWD GMC Yukon 6.2L. From what I'm hearing the stock ones are not being suggested.
Thanks
Once the oil is warmed up, the pressure on the gauge will usually be just shy of 40 psi, the bypass spring on the pump is 33 psi as our oil pumps deliver 1/3 more oil per rev than an iron block motor's pump to compensate for the increased tolerances in our aluminum engines.Thank you for the info. A large majority of the use of this Yukon 6.2 will be pulling a 28 enclosed snowmobile trailer amongst other family outings and trips. So not my daily driver. I'm looking to try and make some improvements for engine life longevity and overall performance. Having said that I will probably go with the H3 mounts. If you have any other suggestions for must have's on these rigs I'm all ears. I have notice lower oil pressure after driving for an hour or so, but it is not consistently low - which is an issue I've read about.
Thanks
Yep. You would hear the piston fighting for territorial rights with a valve in one of those cylinders. It will be a short-lived dispute too, being settled in a matter of minutes or less.The rig has 139K miles on it. Any idea how I would know if a valve spring is broken?
