Look in your glove compartment and see if you see these 2 codes KNP K5L View attachment 188649
The transmission cooler lines are known to be a problem area. There are threads around like this: http://www.cadillacforums.com/forum...ssible-quick-cheap-solution-crappy-leaky.html that show how to fix using some fuel injection hose and double hose clamps.
I did this to my Esky and not a drop in almost 2 years. Much cheaper and likely lasts longer than replacing the hoses that are still prone to leaking at the metal to rubber junctions.
Yes. My Esky is 07. They went over the top in that link. All I did was use a small pipe cutter to cut behind the rubber/metal junctions and got a couple feet of Fuel injection hose and hose clamps. There is not much pressure in those lines. The double clamps seal it up, so no need to flare the metal ends or anything.
Done. Cheap. Better.
The good thing about this is that if it doesn't work for you, you are only out $20 and you can either find another solution or order the OEM hoses.
Good luck
