whistling/Humming sound at 40mph, only during acceleration
Bcox
Lexington KY
I have an 03 z71 and i get a humming/whistling sound when I get to around 40mph. Only hear it as I accelerate. If I take my foot off the gas the noise goes away, then comes back as I accelerate. I've done some research and some say it could be the carrier bearing, or a pinion bearing???? Does this sound accurate to anyone? Has anyone experienced this? Thank you
PG01
Up here to the right
Does it clunk on/off the gas? Or no clunk and just whine? Does it do it in neutral at speed? Or just drive?
Bcox
Bcox
Lexington KY
No clunk, just a whine. Doesn't do it in neutral only when I reach around 40mph during acceleration. If i let off of the pedal it stops, but then when I press on the gas again it starts. Its literally just during acceleration after reaching 35-40mph
shreksbrother
Auburn Hills, MI
Have you considered the possibility of the intake manifold?
I would have bet money that I had a failing bearing (and I'm a pretty accomplished shadetree mechanic). After nearly a year of that sound driving me crazy, I read another member's post about their intake manifold gasket possibly causing a similar sound. I replaced my intake manifold gaskets over the weekend and my ears are SO thankful. Plus my Yukon runs infinitely better!
My gf is complaining about the same issue. Do you need to have your window down to hear it? Or do you hear it with the windows up?
HACK BLOCK
NYC
I hear the same exact same sound.
RGA1215
Texas
My 01 Tahoe has been doing the exact same thing as long as I’ve had it (1 and a half years). It starts around 40-50 mph, and then it starts doing it again at a higher pitch at around 70-80 mph. And mine only does it when I press the gas as well.
mnjeepmale
I have 01 and mine does the same. But I think it's a idler pulley.
Sent from my SM-N950U using Tapatalk
davidmakey230
