Who The Heck Knows???
JUSTWUFN
I have 2004 Yukon that has the following issues:
-HVAC System sometimes does not work at all. I cut off HVAC completely then hit auto button and unit normally works fine then.
-Seat control on driver side. Sometimes when I use FOB or control on side of seat to move seat forward or backwards seat goes in the opposite direction. Example I move lever forward and seat goes in reverse or vice versa
-Radio. Sometimes the radio works find and you stop truck and then later crank back up and radio does not work
-Headlights pulse sometimes when on high beam
I changed battery out a few years ago and started experiencing odd things with vehicle so per site input I took truck to dealer to have control module re-flashed. Truck seemed to work better, but problems did not completely disappear.
Is there a way I can reset computer myself or do I need to take truck back to dealer to get them to re-flash again?
This my wife's truck and she loves the truck other than the fact it is possessed. Ha!!!
Any suggestions appreciated.
YukonXL04
The Riverboat
Arlington, TX
Maybe disconnect the battery for a while? Also check all your main connections.
mneff911
