Will 305/40 r23 fit stock
Cdfarrow
Buying some wheels and might put them on my 08 tahoe does anyone run a 305/40 r23 ??
Welcome to the Forum from NH.
Pics of the truck, please.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components and different wheel widths and offsets, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
SUMTOY2
I have 295 35 24 on my 08 tahoe. Just like Joseph said there are many variables. I had same size dilente tires that would rub a little. I just put citytrac landspider tires on same size but they hardly rub. Oh yah it's also lowered 2/4.
The 305 will rub quite a bit when turning due to the width, 23in wheels are an odd size. Hope this helps.
