Window controls acting weird
Dpounders
I have a 2005 Yukon xl slt and I'm having a rr window problem. From the drivers window controls I can put the right rear window down but not up. If I operate the window from the rr door control it works fine. If I engage the window lock on the drivers door, it appears to operate as it should as I can control the rr window up and down from the drivers controls but the rear control is locked out. Here's the weird part: if the rr window is down and I take the window lock off, it goes up on its own without me pushing anything. Once the window goes up its disabled for about 20 seconds, i hear a click and the the operation returns to how it was before. Any idea what would cause this?
chauncey0337
MLT, WA
I have a similar problem. My LR window goes down but not up with drivers controls and normal with LR controls. This happened right after I changed my window switch lights to leds so I'm pretty sure my problem is the switch. Your problem does sound weird. Can you tell where the click is coming from?
RobertWYoung
Fort Worth
The drivers door module sends it's controls to the other doors via data link through the BCM so it's not easy to tell what the issue is.
Might try swapping the back 2 switches if that's possible, not sure if it is.
