Dealers just replaced the module and here are the instructions on that. if you want just try re-soldering any cold joints you find and reassemble.
Part Number Description Quantity/Vehicle 12463017 Windshield Washer Pulse Control Module 1 (consists of circuit board, cover, and screws) Just about $28 from almost anywhere.
12345739 Goodwrench RTV Silicone Sealant 1 (tube will service 50 vehicles)
Service Procedure 1. Turn the ignition key to the OFF position. 2. Remove the Connector Position Assurance (CPA) and disconnect the
wiper motor electrical connector.
3. Remove the three screws that secure the cover to the
wiper motor and remove the cover. 4. Inspect for sealant on the inside of the cover and then discard the cover and screws.
Important If sealant was found on the old cover, it will be necessary to remove any old sealant from the motor housing in step 6. 5. Carefully remove the module (circuit board) from the
wiper motor by lifting up on the end of the module electrical connector. 6. If necessary, remove any old sealant from the
wiper motor housing (see step 4).
Notice When handling the new module in the next step, be careful not to damage or bend the electrical contacts on the bottom side of the module. 7. Install the module into the
wiper motor housing, making sure that the module is fully seated. When fully seated, the edges of the module circuit board will be flush (even) with the motor housing along all sides.
8. Carefully apply a bead of silicone sealant, P/N 12345739 (or GE-162 sealant or equivalent) in the groove of the NEW cover (Figure 2). Remove any excess sealant that is outside of the groove.
Important Only apply enough sealant to fill the groove in the cover. 9. Install the new cover on the
wiper motor housing and install the three new screws. Tighten
Tighten the screws to 2.6 Nm (23 lb in).
10. Reconnect the
wiper motor electrical connector to the wiper motor assembly and install the CPA. 11. Turn the ignition key to the ON position and check the wiper system for proper operation (delay/low/high/etc.). 12. Install the GM Recall Identification Label.
---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
BTW if you have the old spider design just replace it even if it is not a major issue yet as you have the time and funds.
