Wobbly center console
Kee Fuller
las vegas
ended up swapping out my jumpseat for a center console. It came with the bose amp and rear ac controls. I have a ppv so it doesn’t have the plugs for it so i took out the amp, the metal housing around the amp and the harness. I put Basically the shell and the brackets back together and threw it inside the truck.
The console is kinda wobbly. It’s bolted in correctly but a firm push you can feel the console move. Any ideas?
Big Mama
Virginia
Did the metal housing around the amp bolt down with the bold that hold the console down? If so try a washer or 2.
Kee Fuller
Kee Fuller
las vegas
Update. I put the metal housing back on the bracket and it doesn’t wobble as much. The front right leg is broken, but overall it’s not bad
Paul french
