i have a 2003 yukon 4x4 with 205000k . i let the motor warm up for a good 15min. Put it into reverse and nothing. rev it, still won't go into gear. put it into park. and try it again. same thing, ill leave it in reverse and about 30 seconds or so it will finely go into reverse . Now tonight i started it after work, went into reverse no problem parked for 5 min. then went to drive and off and it wouldn't go into drive. put it into park. then tried again. and went into drive no problem.
- now I've read that if i change the 4wheel drive switched in the dash it'll fix the problem . iv also read there is a sensor in the transmission that needs to be changed and that'll fix it? anyone els have this problem
