won't recognize my driver door is open
FreeIndeed
This has come and gone, but is back again: after I turn the engine off and open my driver door, it should recognize the door is open and turn the radio off etc.. What - or where- is the sensor that tells the computer that the door is open?
Thanks!
NathanJax
Vacation Nathan
Administrator
Jax, Fl
It's built into the latch so that'll have to be replaced
FreeIndeed
FreeIndeed
Yeah, it didn;t work for a couple days and now it's back to normal. Is it mechanical? Do I need to lube or clean something?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
It's the mechanical latch that has an electronic switch built in. You can spray some dielectric grease inside there if you want
FreeIndeed
FreeIndeed
Thanks - I"ll give it a try. I just had the door apart a bunch of times to work on the speaker/connector too -missed my chance!
Joshuasvt
Everett, Wa
Mine started doing this last week. I've been opening and shutting the rear drivers side door as a quick way to get everything to turn off. Guess I'll be looking into the latch now.
FreeIndeed
FreeIndeed
Mine ended up being a power wire to the Driver Door Module was breaking. It finally broke and in the end the dealer found it. There are 2 power leads that come into the DDM you need to check out.
Bearded-dad
