Won't start
Smasal
Southwest, Mo
Just ran my truck bone dry....don't ask, my bad.
Problem is I've put 5 gallons in it and now it won't start. Acts like battery is dead??!
fire730
Louisiana
Did it try and crank at all since you put fuel in it?
fire730
Louisiana
Try and jump it first. How much did you crank it after you ran out of gas?
Smasal
Smasal
Southwest, Mo
Quite a bit. Can't believe I did this. I wish I could some how kick my own ass.....
fire730
Louisiana
Sounds like the battery is toast. Get a new one and prime the pump (cycle the key) a few times before you try to crank it. Hopefully you didnt burn up the pump. But dont be suprised since the pump is cooled by the gas.
_Dylan_
STAY FROSTY
My volt meter in truck is below 9
I've learned that a my truck needs about 11 volts to start.
Get a jump from somebody with a v6 or v8 (4 banger batteries aren't big enough).
Smasal
Smasal
Southwest, Mo
I tried to jump it with my dads 08 CC silverado. Still wouldn't turn. Battery is toast for sure. It's actually a 2 year old battery after closer inspection. So it was probably time anyways. I left it sit where I stopped which is a block from the sheriffs office. In the morning I'll pick up a new battery and let you know. What does prime pump mean? Are you referring to fuel pump?
GregD99
