Wrangler Duratrac 275/65R18 for 2018 Tahoe Z71
mootham40
Goodafternoon:
Just looking for some information on whether the Goodyear Wrangler Duratrac 275/65R18 is compatible with the 2018 Tahoe LT Z71?
I currently have the 265/65R18 and am looking for something that will fill the void without having to modify anything. Any insight or recommendations is greatly appreciated. Thanks!
olyelr
Elk Rapids, MI
Only being roughly a half inch wider and half inch taller i would have to say u would be good.
Ibustbravo
Centennial, Co
They get really loud if you fail to rotate them often. If you install a louder exhaust and turn up the radio the tire noise goes away. Problem solved.
K2 Kaiju
The Depths
They should fit. If you want a little more fill at same width as stock you can do 265/70/18 (they are cheaper too). I have a small level kit, and think 275/70/18 are about max size you can go without a true lift...
PD2770
