Wrench size?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
What size is the larger and smaller fitting for the fuel spider lines in the top back of the engine is it different from supply to return. I have to find my sae stubbies but being an aircraft mech I almost never needed metric tools so I sold my snap-on metric stuff when I needed the cash. Can't afford to get them all back but a few tools to do my spider would be good for now.
I take even though this is an american vehicle I am gonna need to get metric tools for this tahoer. Correct?
oldsalt
Dammit Sunlit, You would have to ask that. I've been through this a dozen times and still have trouble remembering.
I believe the small one is 16 and the larger is 18. If you pick up 15-19 that should cover you.
I don't think Harbor freight has stubbies that big. Maybe Sears.
SunlitComet
SunlitComet
OBS Jedi-Do Good
I also have locking flex ratchets so I could use open end or flare nut crows feet. I will see if I can scrounge enough for a snap-on set. If not then I will look for some temp sears ones. Won't touch the HF tools. When I'm back to work again I am going to stack up on snap-on again. I would not touch any aircraft or high-end/heavy machinery without them.
Thanks guys.
fire730
Louisiana
I dont even unbolt the lines from each other. I just take the 10mm hold down bolt off and disconnect the front with the 2 8mm bolts and just easily move it up out of the way. Just make sure it isn't hitting the trans tunnel when you put it back together.
Well Worn Chevy
