Yet another AC question. Regards to blend doors.
The Arkle
MO
After replacing many a part on my AC I feel very stupid. It started with a blower motor controller (replaced with a beefier one. Old one was a bit worn but might have still worked) and went to the fan control switch. Ended up snapping the brittle plastic on the AC head. Replaced the whole panel recently and most of my fan functionality is back along with the temp control. Works rather well now except for my blend controls. After much searching it was discovered there is an arm from the box under the dash that goes from the actuator and up. After four+ years of no AC we have found the final piece. The arm that goes up to the blend doors has fallen off. The arm goes back up where it should just fine. And this is where my question comes into play.
My question is this: what connects the actuator arm to the blend door? Is it a bolt or like a pin or clasp of some sort? I need to know what I need to keep the two together so the blend will work. If it's a bolt, what size? And if its a pin, where can I get either a new arm or a new pin or something to replace it?
b18cls1
