Hello dear all,
I have a Yukon 2004 4.8l rear wheel drive truck that has a strange thing for me which is draining drops of fluid about half of a litter or more if i leave it more days after removing the battery leaving it in park for about 10 days specially in summer which is very hot about 50C , but it is not draining any fluid drops when i connect the battery again and use it,
I am sure that it is not draining transmission fluid while driving or when it is parked for small periods less than 7 or 10 days.
Also i think that the fluid was burned and i did not know when the last time it was changed but i suctioned out about two litters each three months adding new fluid instead of the suctioned two litters.
Do you recommend suctioning it completely then adding new fluid without removing the filter?
Do you recommend just a fluid change draining the fluid while changing the filter without complete flushing of all fluid?
Do you recommend flushing the fluid completely after doing a suction for all the fluid without removing the filter then later after three months i do a complete flush of all fluid and changing the filter?
Thank you in advance for you help.
