Z95 resistor size
Kev 05 Tahoe
bare with me as this is my first post on here.
2005 Chevy Tahoe RWD z95 suspension. i have already installed Bilstein 4600 shocks. i measured the resistance at the plug in the front (2K ohms) and Rear (7k Ohms) unplugged. Ignition was not turned on.
1. What size watts and resistor do i need?
My guess is 7 ohm and a 2 ohm resistors, correct?
2. what watts do I need though?
3. I have weathertech plugs i will splice to connect to the factory plugs, keeping the factory harness original.
Thanks in advance for the help.
kev
Askold_JB
Sorry, not sure about MagnetRide Suspension.
But AutoRide front resistors are 2.2Ohms 50W and 3.9Ohms 25W at the rear.
Actually it will works with 3.9 Ohms 25W both front and rear.
Check the resistance you mentioned - front (2K ohms) and Rear (7k Ohms)
I think there should not be K - kilo Ohms (x1000), but just Ohms
Snotek27
