ABS light on sometimes....
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
as it says my ABS light comes on sometimes and turns off while driving then comes on again maybe a minute later........and ideas???
---------- Post added at 10:38 PM ---------- Previous post was at 10:17 PM ----------
FYI my parking light brake does NOT come on as well... JUST the ABS light
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
faulty wheel speed sensor. Wont know for sure unless you can get a code pulled.
fatnlowtahoe504
fatnlowtahoe504
ok so i tried to get the code pulled but autozone told me they can only pull check engine light codes, do i need to go to chevy for them to put a diff computer on it to pull the code off?
Chucktown Mako
Does your Parking Brake Light come on as well? Both ABS and Park Brake lights are intermittently coming on in my ride. I am suspecting the ECBM ground. I have already replaced it once. Try to clean up the ground (supposed to be a big 12ga wire grounded to the frame).
jerseyjonny
Jersey
you probably are on the road to needing a wheel bearing, if you jack up the front and spin the wheel you'll probably feel it
fatnlowtahoe504
fatnlowtahoe504
hmm i have replaced both of my hub assembly in the past 2 years....
---------- Post added at 04:21 PM ---------- Previous post was at 04:19 PM ----------
idno if this has to do with it but when i am turning and braking at the same time, if i hit a bump by brake pettal goes limp for a second, idno if that is just anti lock brakes or a problem
Anthony
2004 Tahoe LT (MA)
Westen MA
Maybe the 27s are messing something up? Try running factory wheels (Just for a weekend) to see if the issue still exists. My $0.02
hillcreekfarms
