Make my 5.3 sound like a 6.2. HELP.
Goodinblack
I Like Tacos
Dirty South
Okay, so after hearing the my friends Escalades' stock exhaust I got envy and decided to do a exhaust on my Suburban.
Basically I want my Suburban 5.3 to sound like a Denali/Escalade 6.2. What will achieve this?
I had talked to JD08 and he said he was really pleased with the GMPP Touring.
Originally, I ordered the GMPP Borla exhaust but then had second thoughts and canceled/held the order for now. I am torn between the 24 inch Magnaflow and the 24 inch GMPP Borla. I like the fact the Magnaflow has the proper offset/center that match our trucks. The Borla GMPP Touring is Center/Center. Harder to install?
The only problem is I don't want the dreaded drone, and the AFM gurgling. (I have been reading on forums a lot). Please note I have never really heard the AFM V4 mode and don't know what to expect.
Right now I just have the Resonator Delete, and don't hear anything.
Oh, and Corsa is a no no..... too much $$$. Unless someone knows where to get just the "touring" muffler.
So help guys....:emotions122:
Also, I put this in general discussions as I am more concerned with the sound vs. performance. Though performance is good too.
I'm very please with how good my Magnaflow 12589 sounds especially now that it's "broken" in. Sounds great with little to no cabin drone!!!
Regency
noob
New Orleans
Maybe buy a used 6.2 liters's exhaust? I think it's all 3 or 3.5 inch.... But at the end of the day, theres no replacement for displacement....
felixgun
Lafayette, LA
X2 on this one. Had it on my 08 Tahoe paired with Volant tips+resonator delete and it sounded much better then stock with no drone.
Goodinblack
Goodinblack
I Like Tacos
Dirty South
Hey has anyone run the Resonator AND and aftermarket muffler?
Would that still sound bad when V4 kicks in? Would it get rid of that sound?
Goodinblack
Goodinblack
I Like Tacos
Dirty South
Dang Bro, you know where ALL the stuff is at.......:hands:
---------- Post added at 01:46 PM ---------- Previous post was at 01:44 PM ----------
My Corsa touring is pretty darn close in tone to what my stock Denali exhaust was.
I wish I could swing the dough....... but. Hey what is your opinion on the GMPP BORLA and the 24 inch Magnaflow? As a tuner......:hands:........ Since you may soon be my next mod.
Also, it is true that the V8 to V4 switch gets more apparent (jerky) after the BB tune?
JennaBear
Resident Ninja
San Diego, CA
Exhausts don't really add much performance wise, but they can take away. Of the above mentioned brands, I think you are good to go with whatever fits your wallet!
The V8 to V4 switch will depend on your specific transmission. Some seem to not have as fluid of a transition as others, but that is merely mechanical.
Blazed
Accepting Donations
While we have Jenna in a thread.
Is it possible to literally take the entire exhaust from an escalade headers all the way to resonator and put it on a 5.3 Tahoe?
Goodinblack
Goodinblack
I Like Tacos
Dirty South
^^^^ Going from a 2.75 inch exhaust to a 3.5 may be a bad idea. Would really have no low end left. Someone correct me if I am wrong please.
Blazed
Accepting Donations
Would put manga flow 12909 if that helps someone with possibly correcting or agreeing with goodinblack
totheyard
I am sure GM made their stock exhaust pipe a certain size for a reason. Some back pressure is good.
Blazed
Accepting Donations
No no no that could be right lol I'm sure they did but I can't imagine that the .9 liter of extra engine requires an inch wider exhaust
Blazed
Accepting Donations
Jenna are the headers even different? As far as piping size or does the size difference start at the y pipe?
My mom has an escalade and I've tried to figure this out. To me it looks like the piping the same until the y pipe right before the flange.....? Correct me if I'm wrong.
To clarify I think the tubing going into the y pipe is the same on 6.2 and 5.3 alike but the output of the y pipe is a 3.5 on the 6.2. So basically the 5.3 just constricts at the y?
totheyard
There is a big difference in displacement. 5.3 = 325, 6.2 = 376
JennaBear
Resident Ninja
San Diego, CA
I think the Y pipe would be the biggest issue. We used the same headers on our 6.0L, and when we swapped to L92 heads.
Blazed
Accepting Donations
How would the y pipe create an issue if I'm replacing the entire exhaust
Yizzo88
