ABS & Brake Light Fix
Skizzot
Usa
http://www.youtube.com/watch?v=Jo76ylqgUR8&feature=youtu.be
This video I made shows how to fix intermittent ABS and Brake dash lights on all Chevrolet vehicles with the Kelsey-Hayes 325 EBCM module. You may have code C0265 "Electronic Brake Control Module Motor Relay Circuit." The fault is usually due to corrupted solder joints on the circuit board to which the motor relay circuit is connected and is easily repaired with additional solder. The warning lights are intermittent whereas the poor solder joints result in brief communication interruptions with the relay circuit. The warnings will extinguish when reset (turning the vehicle off/on) and will illuminate again once the circuit loses its communications path. (If it were a bad relay, the warning lights would most likely not be intermittent.)
My ABS/Brake lights got to the point where they would come on after less than a minute of driving. I have now driven my truck over 400 miles without the lights coming on after performing this repair.
Merry Christmas!!
01Konvict
Boats n Hoes
Raleigh/SML
Thats a awesome video the guy made. It took me hours to get the stupid module off anf had to cut off one screw then replaced them all with ss allen cap head. Its an easy fix for the solder joints.
Skizzot
Skizzot
Usa
4k miles and still no ABS/Brake dash lights and ABS works perfect.
cdhayes2
Goshen, IN
Re: ABS & Brake Light Fix
Cant express how excited I am to see this.
Sent from my Galaxy S4
livingez_123
Sandy, OR
Doing mine today as well, t20 to remove from the unit and t9 for the little guys.
Well so far so good. Mine was more temperamental in the hotter weather which makes good sense as to why the light would come on. even if the board looks good it only takes one to get a little warm and loose contact for that split second that it takes to set the light. all of my solder joint looked real good but I ran them all anyhow. I will keep my fingers crossed that this takes care of it. I should have done this 2 years ago!
RAMurphy
Bob
Military
S. Maryland
This is a great video. Completed this repair three weeks ago and I have had no issues to date. My lights were coming on intermittently for several months atleast once per day. I had to remove the entire pump/module since one of the module screws stripped out. Additionally, my module did not have the six screws holding the cover inplace otherwise it was the same module. Hit the six solder points detailed in this video, put it all back together and like I said no lights. Saved a ton of money.
ebxgsxr
Baltimore, MD
glad i saw this. i think this is what's going on with my brother's truck. we will have to try this out.
OmniCamaro
How in the world do you remove this thing? On my 2001 Tahoe there's like 1-2 inches of clearance above it. There's no way to get just this part off by itself. I do not want to take that whole unit out.
Any pointers?
01Konvict
Boats n Hoes
Raleigh/SML
You can get it off but its a pain in the a$$. Its torque head screws and can strip easily. I used a 1/4" ratchet and mine came out with some effort.
Roscoe2352
