Easy 4-Hi mod - Simple All High Chip 03-06 model years
kwOH
Banned
Ordered.
BeenChevy
Minnesota
What exactly does the soldered spade do in terms of auxiliary? Has anyone utilized this?
6HI Mod via diodes (currently)
Have this board in-hand with solder..
jdpber
jdpber
GOLD MEMBER
The America
the aux spade will send a signal to a RELAY that will they take power directly from the battery to power light bars and what not.. EXAMPLE. you click your high beams and it automatically turns on all 6 lights plus the light bar for sunlight laser beams on the dark country road.
the relay can also have a switch wired to it at the dash if you want to turn the light bar on when ever.
BeenChevy
Minnesota
Sweet. So say you have 2 switches already set for aux lights, can you then just piggy back this off the sw feed at the relay(s)?
95escahoe
I'll be picking this up soon, nice easy simple mod
swampfoxjr
I researched Fleece's website and can only find this single board which turns on the fogs and lows when the high beam is activated. It's a great idea, too bad they don't offer options. I forgot how I did my drl mod- they act normal until the headlights are turned on, then they come on whether I'm in drive or not. And the fogs come on anytime the headlights are on. Then there's my 4 hi mod which is actually now an 8 high. And I deleted the auto headlight function since it caused problems with my HID ballasts. It would sure be nice to have control over all these functions from the DIC.
If you buy a relay harness , it smooths it out
Gator Aggie
