Supercharged Tahoe TBSS
gat0r
DFW
looks nice
what stall did you go with?
& did you upgrade output shaft? (if that is even an option)
sumo
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
2800 stall. Yea it's a hardened shaft
Here's specs of the level 4. I went with a different shell. I went with Sonex smart drum
Master Overhaul Kit with Alto Hardened Kolene Steels
Raybestos Gen II Racing Frictions
Filter
New 29 Element Dual Cage Sprag
High Capacity Upgraded Pump Assembly
New Hardened Pump Rings
New 13 Vane Pump Rotor
New Vanes
New Stator
.500 Boost Valve
Pressure Regulator Valve
Updated Boost Valve
Transgo Reprogramming Shift Kit with Shift Command
Bushing Kit
New Thrust Washers
Complete Torrington Bearing Kit
Heavy Duty Hardened Sun Shell
Heavy Duty Expanded Capacity Input Drum with Reinforcing Sleeve
High Rev Spring Kit
Heavy Duty 5 Pinion Front and Rear Planetary Gear Set with Sun Gear
Hardened Output Shaft
Hardened Reaction Shaft and Hub
Super Hold 4th Servo
Corvette Servo
Wide Carbon-Fiber 2-4 Band
New Valve Body Spacer Plate
New Shift Solenoids
New EPC Solenoid
New PWM Solenoid
New 3/2 Solenoid
New Manifold Pressure Switch
New Internal Wiring Harness W/New TCC Solenoid
New Electronic Speed Sensor
New Original Equipment Steel Transmission Pan
30, 000 GVW Hayden Cooler
Transmission Mount
Helluva tranny. I was checking their website out, and if mine ever goes out they are who I'll go with for sure. Not cheap that's for sure but helluva tranny!
sumo
sumo
rhode island
I also dropped 500 on and lightened flex plate and a G on a Yank preformance converter, they adjusted the price because I didn't use the converter that they use for the tranny build. Yank converters and Gearstar work hand in hand. They both built my order.
Once the converter was built, they drop shipped it to Gearstar where they installed it on my freshly built trans and they tested the 2 components together to ensure proper function. After that they shipped the trans with converter installed and filled with fluid ready to install.
gat0r
DFW
sweet specs, that should last you a while
very interested in AAR, after you install & get to enjoy it
Meccanoble
Georgia
I love boost for the BOV sound. You recirculating? If not can I get a clip of that BOV sound?
sumo
sumo
rhode island
There's no bov on a supercharger. Boost is throttle driven. Once you let off the gas it's not boosting anymore as where a turbo it's driven off the exhaust gasses so the pressure still builds when the throttle is closed. Once it gets to a certain pressure the excess pressure gets vented through the bov, other wise if there wasn't a way to vent the excess pressure, something will blow
Meccanoble
Georgia
I had a Vortech Supercharger on a Nissan Maxima and it had a BOV. The BOV is supposed to release excess air that is pushed into the intake. Turbo and Supercharger have different ways of getting air to push in intake but they both produce excess air, right?
M3kanic
You are thinking of a bypass valve.
lady112210
