Tahoe TBSS Intake manifold swap
Alex_M
You will need the TBSS fuel rails.
Reuse your existing injectors, they fit fine with the TBSS intake and fuel rail
Get the Corvette fuel filter to regulate the pressure. This will make your firewall clearance a bit tight for fuel lines, but it works. You'll have to bend the fuel rail inlet up a bit for the body of the filter to clear the fuel rail.
You can get an adapter to reuse your throttle body, or get an aftermarket throttle body. For a stock motor I'd probably just reuse the stock throttle body. Even an 8.1 only shows about a 20hp gain from a larger throttle body than the stock 78mm. Will make fitting whatever intake tube much simpler than the aftermarket TBs.
DeSexingStick
