IMPORTANT: The Chronicles of Low Oil Pressure by 07burb
JonnyTahoe
Minneapolis
yeah, I've sense moved away from the K&N because they're so much higher to pay just to get a nut. I've found a system to where I can get the proper tightness on the filter now. Still a much bigger pain in the tookus than it needs to be but it is what it is LOL
JonnyTahoe
Minneapolis
I have before used just your average filter wrench on the bottom portion of the filter to give it just a bit more rotation without causing any damage to the filter but I try my best to just do it by hand.
Wolfbraid
Winston Salem, NC
Exactly, the wrench adapter is ~$4 malwart just having it on the filter without the wrench gives enough grip to tighten properly.
pwtr02ss
Tennessee
Thanks for sticking this @07Burb and all the others who have chimed in over time. Wife started the avalanche yesterday, "no oil pressure, shut engine off". She calls, I ask if its making any noise. She says, no sounds normal. I told her to drive it home (50 miles). I got home last night and pulled the sensor and screen. Screen was blocked up so I replaced that and we're back in business.
Administrator
Awesome!! Exactly the reason I posted this and stickied it years ago knowing that SOMEONE would have it happen to them, too, and would save them a LOT of troubleshooting and headaches. Glad it all worked out :)
JimHanus
Richmond MI
I am in the process of changing the oil pressure sensor and screen. I bought a 1 1/16" sensor socket with the sensor. The socket fits the purchased sensor fine, but won't go on the sensor in the engine. 2013 Tahoe 5.3. I also tried 27mm and it also doesn't fit. 1 1/8" is too big and drops right over it. Anyone else run into this?
wjburken
Eastern Iowa
Can you see if there is a bunch of crud built up on the existing sensor? If 1-1/16 1.0625”) wont fit and 27mm (1.0629”) won’t fit and 1-1/8” (1.125”) is too loose, maybe a 28mm (1.102”) will work.
JimHanus
Richmond MI
Well, I did manage to get the socket on. Took photos with my endoscope. There is a plastic shield on the rear of the intake that kept the socket from being straight up. Once I pulled it a little I could push the socket on. BUT, you guys must be midgets or have lady-sized hands ;) . I can just barely touch the plug to try to remove it, but that's it. I can't touch the sensor enough to try and turn it after I get it loose (which I couldn't even do). I have a piece of plywood across the top of the engine to lay on just to reach the sensor. I even tried getting into the engine compartment (standing on the steering column). No dice. If anyone has a trick I've missed to reach back there please let me know!
wjburken
Eastern Iowa
Yep! That one’s a PITA to get to. Might need to take the intake manifold off or wrangle a skinny armed kid. I shoved my arm in on mine and I think it took three weeks for the cuts and bruising to go away.
Geotrash
Dave
Richmond, VA
Just remove the intake manifold. Easy job and doesn't take long, plus you can get a fresh manifold gasket in there and torque it properly. My hands were too big to get back there without pulling it. Been running fine for 20K since.
ChuckWoodChuck
