HOW TO: Convert to Escalade LED Tail Lights
BG1988
You’d be in the same situation. You’d have to swap both the hybrid lights as well as the upper appliqués and I think the third brake light too
it's 5 pin like the reg tahoe
unlike the caddy which is 6 pin no chopping wires it's 2008-2013 it's the same style but with LEDs
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
looks like the hybrids have a different shape than the standard tahoes and require the upper appliques to fit right. if not they are still just as ugly as the oem ones. id rather buy some aftermarket led lights over the hybrid ones.
BG1988
I don't like the Cadillac ones are they strobe badly , the LED driver in them suck or the LED them self suck..
what good does having very bright break lights if they blind the driver behind you?
as it uses the OLD 1980s conventional LEDs
I have seen a few escalade pass me by I get blinded by them. because they strobe..
even the cheap aftermarkets ones have those ones at 25% brightness
the tahoe tail lights use
Chip-on-board array and a decent LED driver The person who designed the LED array/LED driver in the reflector did a good job.
what does the applique have to do with the tail lights
you referring to part#1 on the image correct?
mazdawg(Mikey)
Lancaster SC
No sir I was talking about the piece above the tail. It’s got a hard body line that starts in the light and runs upward into it. Makes sense about the leds and all. I like the smoother clean look of the Escalades and think the oems looks lumpy.
BG1988
oh the "d"
Pillar
there is enough red ontop for that not to be an issue
mazdawg(Mikey)
Lancaster SC
You can
oh the "d"
Pillar
try to correct me all you want and push your negativity but gm calls them appliqués. If you don’t like the escalade lights then don’t buy them. It must not be too big of a problem being too bright since it’s a factory part.
BG1988
You can
the issue is with the LED driver used it's cheaply made that is why Cadillacs have such a high failure rate for the LEDs
plus since it has a LARGE LED array will mean failure of LED rows (as seen on many Cadillacs)..
THE YETI
THE YETI
Director of Operations
South FL
You can
Appliqué is correct.
91RS
GA
I'm confused as why two resistors are needed per lamp? Why does the brake lamp need one also? It should be just the turn signal that needs the resistor?
petethepug
Michael
SoCal
Post # 58 has something about needing only one resistor to keep it oem.
CWinstel79
