Airbag impact sensors
NoReverseYukon
NE Wisconsin
Pulled 4 of these a while back and forgot about them. I have 2 with this # : airbag impact sensor.jpg
...and 2 with # 15103522. I can't remember what years I pulled these from, but if you have the ABS warning light, you know if this is what you need to fix it. I think $10 each is what I was charged, so that plus shipping is the price.
Thanks
Just a helping hand for the #15103522--it fits:
2005, 2006 and some 2007 Chevrolet Silverado, GMC Sierra, Cadillac Escalade, Avalanche, Suburban, Tahoe, Yukon!
check by looking under your front bumper, sensors attached under front frame.
Your sensor's part number printed on yellow sticker should be 15103522, 10370149 or AA10028 (these 3 sensors interchangeable), check by looking under your front bumper, sensors attached under front frame.
If your sensor number different than these 3 part numbers, then it will not work with truck's airbag system.
NoReverseYukon
NoReverseYukon
NE Wisconsin
I know that I pulled them from vehicles that had no front end damage. If my 2001 Yukon used this type of sensor I would test them, but I only have a single sensor that looks nothing like these.
Ok, I'll give it a shot. My zip is 07734--NJ. Thx Matt. Also--did you see my response on your other thread? About the fuse box cover.
They changed the way they mount around 2010 so I knew it wouldn't fit mine, on the 2010+ they reverse thread mount from the back and a use a hex bit.
shawn bailey
Pulled 4 of these a while back and forgot about them. I have 2 with this # : View attachment 252152
Thanks
Do you stillbhave any with the number15103522 left? If so I really could use one. But would buy both if you had them incase one went bad. Let me know. Thanks
Bigburb3500
