HOW TO: Remove Door Panels 07+
Shimmy23
WA
Just installed my chrome handles today. Thanks Robbie and thanks OP for the DIyer thread
Monz11
Wallace, NC
Looking for 12 Hoe metal door handles, no luck - anyone have a line on where I can get metal ones. OEM, etc are all plastic!
Raptor Tahoe
ok. so some guys were talking about paying someone to do this (why can't I live around them? :(), so I decided to do a quick write up on how to do this.
tools needed:
3/8 drive ratchet
6" extension
10mm deep well socket
standard tip screw driver
ok. i don't take my door panel all the way off because it's not necessary.
step one: remove plastic trim pieces like so:
grab here and pull
pry gently in the indention
pry gently underneath
step two: remove 3 10mm bolts from below the armrest and inside the door handle:
step three: unclip switch bezel (only if changing the mirrors, if doing door handles, skip to step four.)
step four: grab the door panel here and pull to loosed the clips. when one is loose, work your way around the door panel and remove them all.
step five: lift up on the door panel to get it out of the "groove" that makes it flush.
by now the door panel will be dangling by the handle cable. it'll take the stress, no worries.
step six: decide if you're doing mirrors or handles THEN move on to step seven.
if you're changing the mirrors:
step seven: unplug the factory connectors from the back of the driver or passenger door module (switch pack).
step eight: remove the wiring harness from the door. (no pics, but held in by white clips, pull them out with needle nose pliers)
step nine: unbolt the mirrors by removing the 3 10mm nuts shown here:
step ten: put it back together using the opposite steps
if you're changing the door handles:
step seven: unbolt the door handles through the 2 holes shown here (2 10mm bolts, don't drop them):
step eight: unhook the latches from the handles (no pics) and slide the handle towards the front of the vehicle and pull them out.
step nine: reinstall using the opposite steps.
Great write-up and pics! Thanks.
BAMAUSAF
