2007 Chevy Tahoe 2WD has been lowered and I want to raise it back up to factory . It is to low in my town and always bottoming out , can I use
If your truck was lowered, chances are that the OEM rear springs were replaced by shorter ones. So, IMO, you'd have to replace those springs as well.
C
Corley1974
Thank you , yeah it has a short spring on it , do you know what spacer I need to buy for the front coil spring to level with the new factory rear spring
can I use the same rear coil springs that look very small or cut down
Just see what parts were used to lower it and swap them out with stock parts. There are people all over with lifted and lowered rigs that would give away or cheaply sell their stock parts. I see 'em all the time on Marketplace. Or, tell us where you're at and maybe there's a forum member nearby that wants to lower theirs and would trade you their stock parts for your lowered parts.
Maybe post an ad on Marketplace to see if someone would swap you and do the work or help you as part of the labor to earn their "free" drop kit. Might make a new GMT900 friend out of it.
vabc
