Oil pressure low
Mfitz725
Hi! 05 Tahoe 5.3L. Installed pick up tube o-ring. On initial startup seemed to have fixed the problem. However, after running for a few minutes got oil pressure low again. Where should I go from here? I'm relatively new to Tahoe/GM products and haven't a clue as to where to go next. Any help would be greatly appreciated.
Multnomah Falls
Military
Help us first. What exactly is the "low" oil pressure reading at cold start, idling as warming up, idling after warm, rev engine in park, driving and when accelerate? Have you attached a scanner for readings or a pressure gauge? You may have great pressure and wrong readings.
Super Moderator
Elev 5,280
I'd be surprised to find an oil pressure PID in an NBS. Prove me wrong, please, or at least surprise me!
M
Mfitz725
Thank you for responding. I came across a post regarding my issue, changed to an A/C Delco filter and the problem was solved.
Marky Dissod
would you share what oil filter you were using that caused this low oil pressure?
Or at least share the post / thread that addressed this issue?
M
Mfitz725
Well I guess I spoke too soon.
Cold start pressure seems OK but as soon as it warms up low oil pressure warning comes on below 1200 rpm. As soon as I pass the I200 rpm mark pressure goes up and warning stops. I switched to a 10w 40 oil and tried adding a Lucas oil treatment to no avail. Can someone point me in a direction?
Skywagon
