L8t 427 Whipple charged Denali
CMoore711
@WestTxDenali Any updates or progress yet?
We getting close to a start up vid?
You sticking with OEM exhaust manifolds and throwing some long tube headers on this bad boy to breath? Details on the exhaust set-up?
W
WestTxDenali
Man I’m so sorry. I had to head back to work early and will be back home next week. That being said I did get the block slung in and started working on the wiring harness. As for the exhaust I have a set of 1 7/8 kooks long tubes I need to wrap and get put on also. I got ahold of Whipple the other day and it is still a few weeks out.
I did end up ordering a set of Viking coil overs and a wilwood big brake set up.
When I get back home I’ll upload some more pictures and hopefully be able to get some more done.
CMoore711
No reason to apologize man. Life happens. You will love the Wilwood BBK set up.
Coilovers and BBK your wife's going to have a one hell of a Denali!
W
WestTxDenali
Even though I’m stuck at work I figured I should do a quick run down of the build over all.
Thompson Motorsports l8t 427 short block
Callie’s compstar rods/pistons/crank
Ati dampener
LME vvt delete
LME valley cover
LT4 hpfp
FIC 30% over LT4 injectors
Atomic drop in low side 475 pump
Katech Cnc ported lt1 heads
GPI stage 2 blower cam 226/250 .639/.639 116+3
1 7/8 kooks green catted headers
Mishimoto radiator
Mishimoto trans cooler
Whipple gen 5 3.0 blower
Katech 112mm throttle body
Mighty Mouse catch can
Katech coil relocation brackets
8l90 trans
Circle d billet stall convertor
Gulf coast drive shaft
Viking coilovers for the front
Drop springs with Viking shocks in the rear
Adjustable 4 link by apoc
Spohn adjustable rear panhard bar
Wilwood 16 inch from brakes
Wilwood 14 inch rear brakes
Djm lower control arms to correct camber
Dropped roughly 3/4
W
WestTxDenali
Alright I made it back home and knocked out quite a bit today. Got the trans back in and the torque converter bolted up and torqued. Drive shaft slide right in and is so much smaller around than the stock unit. This will be nice when I get it sitting lower so clearance. Also started getting the front drive back on and all the misc wiring hooked back up. Also I got the Katech coil relocation brackets in and mocked up. I am still waiting on the super charger to show up. Last update said it should ship out the 25th of this month. Also ran into a little snag with the ati damper. I forgot to order the front 6 rib pulley. Thankfully summit is only 2 hours from the house and it should be in tomorrow afternoon. Hopefully tomorrow I will get started on dropping the fuel tank and getting my low side pump installed.
buckwild27
Have you rewired the fuel rail psi sending unit plug yet?
W
WestTxDenali
@L8T BURB had to do it on his. I'm looking at doing this swap myself on my 2014. So I would like to know where the wire needs to go.
So l8t used a new engine and wiring harness. I reused my l86 harness. For 19-24 they changed the high side wiring. Before that it’s the same connector.
L8T BURB
Kentucky
I used my L83 wiring harness and L83 ECM. The only wiring that was changed was a fuel rail sensor 2 wire to 3 wire.
cervantesjesus174
